STM32F042 RTC ACCURACY
‎2016-01-28 03:42 AM
to be migrated, sourceId: 62564:697285D7-A9CA-445D-B16C-F23BF0E3B1A3
#lsi-rc #stm32f0 #rtc #stm32f042- Labels:
RTC
STM32F0 Series
‎2016-01-28 04:20 AM
> I need to use the RTC in STM32F042 mcu and I'm using the internal oscillator LSI RC. I did a test and found that the RTC is not running with the precise clock. In 30 minutes there was an error of about 5 minutes. This is the most suitable osclilador for RTC?
No. RC oscillators are inherently imprecise. There is a reason people use crystals in oscillators. Read the LSI section of datasheet. > Is there a way to calibrate it? Sort of, but if you need to ask, you probably don't want to do it. > I should use the HSE_RTC clock for more accuracy? Yes. Or use a package where the OSC32 pins are present, and use LSE with appropriate 32.768kHz crystal. JW- Mark as New
‎2016-01-28 05:16 AM
If the clock is NOT actually 40 KHz then setting the Prediv to be 40000 is going to result in obvious walk-off. Step one would be using divisors that match the source.
The LSI has a pretty wide range, and is not inherently very stable.Up vote any posts that you find helpful, it shows what's working..
‎2016-02-01 11:39 AM
Okay clive1, I use HSE_RTC clock and accuracy improved significantly. But I'll have to use the LSI because I found that the HSE is turned off in STOP_MODE and unfortunately I can not use another package with OSC32 pins. I appreciate if you can give me any tips on how to calibrate/improve LSI clock. Something like check the real clock and reconfigure the pre divider would be valid? Thank you!
‎2016-02-01 12:01 PM
You'd need to bench LSI against a crystal source clocking TIM14. I'm looking at RM0360, not sure that's exactly the one for your part, but it's not a part I'm using.
You should be able to measure 1,2,4 or 8 periods of LSI against a lot faster clock, while remaining within 16-bits. This would give you a baseline for your board/voltage, and apt to be a lot closer to reality than using ''40000''. You'd take your measured frequency, and then factor that into the prediv settings.Up vote any posts that you find helpful, it shows what's working..
‎2016-03-29 01:40 PM
Hi, I'm here again! Now I put an external 16MHz oscillator. I measured the frequency of the crystal with the oscilloscope and seems to be all right. But now I have an error of 12 minutes to every 24 hours. My application is totally dependent on the correct RTC and should work for 45 uninterrupted days.So I wonder if this error is normal for an external crystal or there may be something wrong with my settings.
/* RTC init function */
void MX_RTC_Init(void)
RTC_TimeTypeDef sTime;
RTC_DateTypeDef sDate;
RTC_AlarmTypeDef sAlarm;
/**Initialize RTC and set the Time and Date
hrtc.Instance = RTC;
hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
hrtc.Init.AsynchPrediv = 125;
hrtc.Init.SynchPrediv = 4000;
hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
HAL_RTC_Init(&hrtc);
sTime.Hours = 0;
sTime.Minutes = 0;
sTime.Seconds = 0;
sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
sTime.StoreOperation = RTC_STOREOPERATION_RESET;
HAL_RTC_SetTime(&hrtc, &sTime, FORMAT_BIN);
sDate.WeekDay = RTC_WEEKDAY_MONDAY;
sDate.Month = RTC_MONTH_JANUARY;
sDate.Date = 1;
sDate.Year = 0;
HAL_RTC_SetDate(&hrtc, &sDate, FORMAT_BIN);
//Enable the Alarm A
sAlarm.AlarmTime.Hours = 0;
sAlarm.AlarmTime.Minutes = 0;
sAlarm.AlarmTime.Seconds = 0;
sAlarm.AlarmTime.SubSeconds = 0;
sAlarm.AlarmTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
sAlarm.AlarmTime.StoreOperation = RTC_STOREOPERATION_RESET;
sAlarm.AlarmMask = RTC_ALARMMASK_NONE;
sAlarm.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_ALL;
sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_DATE;
sAlarm.AlarmDateWeekDay = 1;
sAlarm.Alarm = RTC_ALARM_A;
HAL_RTC_SetAlarm(&hrtc, &sAlarm, FORMAT_BIN);
‎2016-03-30 02:43 AM
Are you sure?
Consult the RTC prescaler register chapter in RM, and Cube's manual's RTC section.
‎2016-03-30 06:08 AM
Thank you JW, it's my fault. The dividers starts from 0. Probably this is the problem isn't?Now I will test with this setting: hrtc.Init.AsynchPrediv = 124;
hrtc.Init.SynchPrediv = 3999; Unfortunately I cannot configure the asynchronous prescaler to a high value because it will generate a small error. For reference below the RM0091p573/1008 note:
