STM32F030R8T6 TIM1 PWM NO WORK FOR STM32CUBEMX
JACK TAN
Posted on March 27, 2017 at 19:20
HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_3);
HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_1);
HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_2);
HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_4);
__HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_1,40);
__HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_2,80);
__HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_3,120);
__HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_4,190);
//TIM1SETUP(cubeMX CODE):
/* TIM1 init function */
static void MX_TIM1_Init(void)
TIM_ClockConfigTypeDef sClockSourceConfig;
TIM_MasterConfigTypeDef sMasterConfig;
TIM_OC_InitTypeDef sConfigOC;
TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig;
htim1.Instance = TIM1;
htim1.Init.Prescaler = 24;
htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
htim1.Init.Period = 200;
htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim1.Init.RepetitionCounter = 0;
htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 0;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
Error_Handler();
sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
sBreakDeadTimeConfig.DeadTime = 0;
sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
Error_Handler();
HAL_TIM_MspPostInit(&htim1);
Khouloud GARSI
Lead II
Posted on March 28, 2017 at 13:00
Hi
In 'stm32f0xx_hal_msp.c' file, the alternate function should be correctly configured.
This line should be integrated:
GPIO_InitStruct.Alternate = GPIO_AF2_TIM1;�?
This should solve your problem.
Sorry for any inconvenience it may have brought.
Khouloud
6 REPLIES 6
JACK TAN
Posted on March 27, 2017 at 19:22
STM32CUBEMX V4.20
Khouloud GARSI
Lead II
Hi
Khouloud
Khouloud GARSI
Lead II
Posted on March 28, 2017 at 17:37
Hi
For the PWM to be generated correctly, even for TIM3, you have toadd the line below:
GPIO_InitStruct.Alternate = GPIO_AF1_TIM3;�?
Khouloud.
Posted on March 28, 2017 at 17:03
Why TIM3 doesn't need to be set Alternate function?
else if(htim->Instance==TIM3)
/* USER CODE BEGIN TIM3_MspPostInit 0 */
/* USER CODE END TIM3_MspPostInit 0 */
/**TIM3 GPIO Configuration
PC6 ------> TIM3_CH1
PC7 ------> TIM3_CH2
PC8 ------> TIM3_CH3
PC9 ------> TIM3_CH4
GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
Posted on March 29, 2017 at 16:27
HI
Posted on March 29, 2017 at 16:34
HI.I use tim1 pwm,tim3 pwm and tim15 pwm.And addAlternate set,tim1 pwm and tim3 pwm work,but tim15 no work.
________________
Attachments :
SIGN_K.ioc.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HykE&d=%2Fa%2F0X0000000bBp%2F06rZCKvCb2e6r_Pw88IlcpEmHX9E9RZwy.4qMA7Kyfk&asPdf=false
