STM32F030 IS NOT PROGRAMMING SUCCESSFULLY
DG.10
Hi, we are using STM32f030 micro controller for our tracking device design. We have programmed some boards successfully using STM32 debugger. But in one board we are unable to program the code. there are some data saving to the controller memory while programming, but program is not successfully completing.
Is the issue with the controller ?? Please help to debug the problem.
1 REPLY 1
Ozone
Lead III
Most probably the board is damaged.
With the scarce information you provided, this is only guesswork.
