stm32f0 adc dma multi channel problem
superK
1.  ADC setting
hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = ENABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = ENABLE;
  hadc.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
  if (HAL_ADC_Init(&hadc) != HAL_OK)
    Error_Handler();
  /** Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_4;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_5;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_6;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_7;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_8;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_9;
    Error_Handler();
2.DMA Setting
 hdma_adc.Instance = DMA1_Channel1;
    hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
    hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
    hdma_adc.Init.Mode = DMA_CIRCULAR;
    hdma_adc.Init.Priority = DMA_PRIORITY_VERY_HIGH;
    if (HAL_DMA_Init(&hdma_adc) != HAL_OK)
      Error_Handler();
3. DMA START
unsigned short Test_adc[6];
 HAL_ADC_Start_DMA(&hadc,(uint32_t *)Test_adc,6);
Results of testing with ADC DMA configured in the Cube IDE
Only the first value is sampled and entered.
Please tell me what should be corrected to convert correctly.
TETRAVAL
"Your ADC & DMA are well configured. Please make sure that MX_DMA_Init(); is called before MX_ADC_Init();
It should work like that."
in my code dma is defined before adc but still sample from dma adc once and i set dma circular mode i not set dma normal mode
GwenoleB
Hello @superK​,
Best Regards,
Gwénolé
TETRAVAL
