Mike Hooper
STM32CubeProg will not connect via USB to my target board
  • April 28, 2018
  • 5 replies
  • 889 views
Posted on April 28, 2018 at 20:10
I downloaded the STM32CubeProg from the STM website. It appears to install a couple of USB drivers. However, it does not recognize my custom STM32F7 board that is in DFU mode. Per the User Guide I have uninstalled the DfuSe USB driver, but the
STM32CubeProg still cannot see my board. If I reboot my board, the DfusSe drivers are automatically re-installed by Windows. Am I doing something wrong?
    Posted on May 02, 2018 at 14:36
    Hello
    Hooper.Mike
    Do you get an error message ?
    Please, confirm if you have the same issue in this
    https://community.st.com/0D70X000006SskYSAS
    , as there is a known issuewithSTM32CubeProgrammer to connect with STM32F7 board and will be fixed in the coming release.
    Best Regards,
    Imen
    Mike Hooper
    Posted on May 02, 2018 at 15:04
    No error message. The STM32CubeProg simply does not recognize the USB DFU device.
    Posted on May 02, 2018 at 15:34
    Hi Mike,
    You may try the proposition to use zadig program or
    force the update to the new driver
    as mentioned in this discussion
    https://community.st.com/0D50X00009XkXagSAF
    Please keep me informed about your progress on this.
    Best Regards,
    Imen
