STM32CUBEMX STM32F103CBT6 USB Virtual COM problem
‎2017-01-15 6:40 PM
1. I'm using Maple mini of STM32F103CBT6 microcontroller.
2. I use trueSTUDIO.
https://www.sparkfun.com/products/retired/11280
I created USB Virtual COM with CUBEMX. (4.0)
It looks very simple and nothing wrong.
But it does not work.
I have confirmed that the board is normal.
If I replace the boot loader, it will work normally.First, I set it as follows.
But Device Manager does not even search for new devices.
So I tried the same test on the Nucleo F446RE.board.
But the same problem occurred.
It does not appear in Device Manager.However, I changed the settings below and succeeded in normal operation.
vbus_sensing_enable = DISABLE;
But I want to use it in STM32F103CBT6 and STM32F103RET6. (for test)
I attach a file generated from cubemx.
I need help.
Thank you.Please let me know if there is someone who is working normally.
If it is affected by the ide tool, please tell me about the possible tools.
‎2017-01-20 6:19 AM
Resolved.
Thank you.I did not understand it, rather than solving it.
Maple mini board does not work normallyI bought a 'nucleo-F1103RB' board and it succeeded immediately.The cubemx code was generated correctly.
I first knew that cubemx was a c code.
I also found that it is not easy to call c ++ code like visual c.
I do not want to develop with c, so I think it's time to switch back to Aduno or ASF(Atmel software framework)
I was so shocked.
‎2017-01-16 12:19 AM
Hello
lee.namhun
I have moved your thread to the
where someone should be able to assist you.Thanks
Oli
‎2017-01-16 4:26 AM
Hello
lee.namhun
‌,Try to increase heap and stack sizes. Then, please let me know if it is OK with this suggestion.
Imen
Imen
‎2017-01-16 6:19 AM
Thank you very much.
I tested it.
Heap: 0x2000
Stack: 0x4000I have been searching and testing most of the last three days as below.
Https://community.st.com/search.jspa?q=stm32f103*%20USB
I have tried other examples too.
(STM32Cube_FW_F1_V1.4.0 \ Projects \ STM3210C_EVAL \ Applications \ USB_Device \ CDC_Standalone)
But there is a problem.
The usb clock does not seem to match.'Appears as unknown device.'
I would appreciate it if you could give me an example to try.
I am very suspicious of the code generated by cubemx itself.
But I do not have the ability to check.- Mark as New
‎2017-01-16 8:41 AM
Maybe you would check the clock setting and your
configuration used. Y
ou can
refer to your related reference manual for more clarification about the configuration to use.
Or check if this is due to error in device descriptors.
Imen
Imen
‎2017-01-20 6:19 AM
Resolved.
I was so shocked.
