STM32CubeMx HAL_SPI_Receive ?
‎2015-10-06 2:59 PM
Guys,
I want to send a command and then retrieve the output on MOSI line ... Is the right way doing it ?int resultvalue = 0;
uint8_t data7[2] = { VS_READ_COMMAND, addressbyte };
HAL_SPI_Transmit(&hspi1,data7,2,1000);
then :
uint8_t data8[1] = {0x00}; <=== is it declared properly ?
resultvalue = HAL_SPI_Receive(&hspi1,data8,1,1000);
resultvalue <<= 8;
resultvalue += HAL_SPI_Receive(&hspi1,data8,1,1000);
return resultvalue;
Thanks a lot
‎2015-10-07 3:00 AM
HAL_SPI_Receive()
will return a status, but not the received data!
Try this:
resultvalue = data8[0];
resultvalue <<= 8;
resultvalue += data8[0];
‎2015-10-09 2:07 AM
So it will be:
unsigned char Mp3ReadRegister( unsigned char addressbyte)
Mp3DeselectData();
Mp3SelectControl(); //XCS = 0
data8[0] = 0;
resultvalue <<= 8;
Mp3DeselectControl();
return resultvalue; //??16??????
Please correct me if I'm wrong, thanks
‎2015-10-09 7:35 AM
How can I receive data from SPI1 on STM32CubeMX then ??????
‎2015-10-11 11:11 AM
Not sure the world always works like that, you have to take some responsibility to think, test and evaluate why things aren't working. Do you think casting a 32-bit integer into an 8-bit unsigned char is an effective way to pass back the value you have just read?Up vote any posts that you find helpful, it shows what's working..
‎2015-10-16 2:20 PM
Hi clive, thanks for correcting me....
Which one is 32 bits ones ?.... Let me find out.... So 32bits to 32bits.....and the container size = the sender size I'm not focusing on it....I'll be slowly reading it..... Thanks again..- Mark as New
‎2015-10-16 2:25 PM
Like this : it's char ( 8 bit )...., please correct me if I have mistake, thanks
unsigned char resultvalue=0;
Mp3DeselectData();
data8[0] = 0;
resultvalue <<= 8;
return resultvalue;
‎2015-10-16 4:52 PM
No, you really need to study up on C types and how numbers are represented.
Look, you can't use a 8-bit variable to hold some thing that's going to take at least 16-bits to represent. If you shift that value from an 8-bit variable by 8 to the left the data is going to fall off the end, and disappear.uint16_t Mp3ReadRegister( unsigned char addressbyte)
uint16_t resultvalue=0;
Mp3DeselectData();
resultvalue = (uint16_t)data8[0] << 8;
resultvalue += (uint16_t)data8[0];
return resultvalue;
‎2015-10-17 6:00 AM
How do you reckon if I made like this,
I worked when I compiledunsigned int Mp3ReadRegister( unsigned char addressbyte)
unsigned int resultvalue=0;
Mp3DeselectData();
data8[0] = 0;
resultvalue <<= 8;
it,
‎2015-10-17 6:10 AM
How about transmiting ?
Am I correct replacing SPIPutchar ?void Mp3WriteRegister(unsigned char addressbyte, unsigned char highbyte, unsigned char lowbyte)
Mp3DeselectData();
uint8_t data6[4] = { 0x02, addressbyte, highbyte, lowbyte };
//uint8_t data6[4] = { VS_WRITE_COMMAND, addressbyte, highbyte, lowbyte };
HAL_SPI_Transmit(&hspi1,data6,4,1000);
//HAL_SPI_Transmit_DMA(&hspi1,data6,4);
SPIPutChar(VS_WRITE_COMMAND); //????????
SPIPutChar(addressbyte); //????????
SPIPutChar(highbyte); //????????8?
SPIPutChar(lowbyte); //????????8?
Thanks a lot
