STM32CubeMx Feature request : remove date / time in generated files headers or do not regenerated identical files
JulienD
Senior
Posted on May 09, 2015 at 19:41
Hi
All generated file headers are providing date/time in their headers.
When doing a re-generate code, some files are re-created exactly the same
except the generated date-time.
That's really annoying when using version control system which asks you to
commit changes while obviously there are not.
I can see two solutions for this issue ;
- remove the date-time from the file (useless when using vcs but may be usefull...)
- compare the new generated ''active code'' of the file and write on the disk only if there
are changes.
Julien
4 REPLIES 4
qwer.asdf
Senior
Posted on May 11, 2015 at 11:04
Just adding my vote for this feature.
Rob.Riggs
Senior III
Posted on May 12, 2015 at 14:54
+1
jesper
Posted on May 17, 2015 at 11:26
+1
Really annoying, makes the commits hard to navigate and hides the real changes.
Amel NASRI
Posted on May 19, 2015 at 18:08
This request is already raised in
https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Java/BUG%20stm32cubemx%20on%20every%20save%20change%20some%20values%20randomly
. It should be implemented in next release (4.8.0).
-Mayla-
