2014-04-08 01:44 AM
Hi all,
When i launch ''generate code'', MXCube say me ''The firmware package ... v1.1.0 is not available in your repository ...do you want to download this now ?'' ... Yes A popup appear and say ''Problem diuring download, ... MD5 cheksum is not good'' Have you an idea to correct this error ? Is it possible to install manually this FW ? Big Thanks Thierry2014-04-08 02:06 AM
Hi Thierry,
Do you have firmware version V1.0.0 locally installed? Try not to download new version & use this one. What do you get? -Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
2014-04-08 06:10 AM
Hi Mayla,
I found how manualy attached FW in my space area. It must be in another HDD (D:/users/...), not on STM32Cube root. Thanks for help. Thierry
