STM32 clock Jitter on TIM4
‎2014-04-01 11:56 PM
Hello everyone, I'm using STM32F100V8 and I configured TIM4 to generate a square wave (for uart sw). The TIM4 is so configured and should have the highest priority:
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure); TIM_TimeBaseStructure.TIM_Period = 1; TIM_TimeBaseStructure.TIM_Prescaler = 405; TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); TIM_ITConfig(TIM4, TIM_IT_Update , ENABLE); NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); Inside the ISR of TIM4 i toggle a MCU line and my scope show me that the clock has a very high jitter; Could someone give me some suggestion to make te clock more stable ? Here attached an image from my scope acquired on a long time with infinite persistence time #stm32-clock-jitter-tim4- Labels:
TIM
‎2014-04-02 12:47 AM
Don't toggle the output pin ''manually'' in the ISR. Rather, use one of the output compare channels and set it to change state in the ''future'' as needed.
A completely different approach may be to use the timer as trigger for DMA transferring from a prepared array in RAM to GPIO. JW- Mark as New
‎2014-04-02 2:37 AM
Thanks for the reply. Could you please explain me why I can't toggle the pin manually inside the ISR ?
‎2014-04-02 3:00 AM
... to avoid the jitter caused by the zillions of factors causing variable latency of the ISR....
Mind, this is NOT a microcontroller. It's a SoC with relatively loosely (as far as timing goes) coupled modules. JW- Mark as New
‎2014-04-02 6:42 AM
You can, but it's the stupid plan, the TIM peripheral is capable of toggling pins on a hard time line, or generating pulses, etc directly. If you do it in software you get to see all the latency and variability in the servicing.Up vote any posts that you find helpful, it shows what's working..
‎2014-05-05 1:28 PM
I have the similar problem. I am relying on the timer to provide constant timing for ADC sampling. SPI command is used to read the ADC. The CS pin negative edge starts the acquisition. I manually set and reset the CS pin in the interrupt routine, but the CS pin has high jitter. That adds lots of noise to my FFT plot. Is there a way to minimize the jitter? I am using STM32F415
‎2014-05-05 5:10 PM
You could presumably drive the CS pin as a TIM PWM signal, you could cause the pin to go low for a prescribed period, one into which you'd then perform your SPI transaction, starting it in the CCx interrupt
‎2014-05-06 12:20 PM
Sorry, I was not clear in my explanation. For the ADC that I use, both CS and SCLK must not have jitter. The ADC actually starts the acquisition at the fourth rising edge of SCLK. I understand your comment about using the PWM output as the CS signal, but that doesn't solve the jitter problem for SCLK.
‎2014-05-06 12:50 PM
Perhaps you can use a TIM triggered DMA into the SPI peripheral?
Other than that you might want to get the hardware sequencing handled in a CPLD?Up vote any posts that you find helpful, it shows what's working..
