2023-07-27 4:04 AM
Hey there!
I am testing the communication between 2 STM32H7 custom-made boards using CAN bus (chip: SN65HVD230).
My issue is that both ends communicate (Transmit and receive) despite the configuration filter IDs (1 & 2) I am setting. I also tried to block nonmatching addresses using this function: HAL_FDCAN_ConfigGlobalFilter, but it blocks reception from all addresses.
Any ideas?
2023-08-01 2:18 AM
Hello @Tee,
Could you share you Rx filter configuration and the input parameters of the global filter configuration
Thank you!
