2024-03-12 8:22 PM
I am reading AN2606 and I am wondering if I am interpreting the document correctly. Is table 113 suggesting that the FDCAN bootloader is only available on pins PH13 & PH14 in the STM32H75 series? Since these pins do not exist on the 100 pin packages of the part, is it not possible to use the FDCAN bootloader on 100 pin packages?
Thanks.
2024-03-12 8:58 PM
Correct and correct.
2024-03-12 8:58 PM
2024-03-13 12:14 AM
