2013-07-29 05:24 AM
I have a question, I'm doing the robot. Is it possible to feed the controller from the battery and usb or is it dangerous?
2013-07-29 06:04 AM
should not be a problem using a couple of diodes the dangerous part is if you try to charge the battery. Erik
