Speed of STM32F10vct6 FSMC interfacing with TFT LCD
sruthi
Posted on August 08, 2016 at 14:14
The original post was too long to process during our migration. Please click on the attachment to read the original post.
1 REPLY 1
Posted on August 08, 2016 at 15:23
Is that the maximum speed
It's is constrained by the resolution and the bandwidth of the bus. Compute the data rate over the bus based on your clocks, and configuration. Use a scope or logic analyzer to confirm the bus performance.
Then ask yourself
What is the application?
What FPS your application needs?
How much data would that rate generate per second?
What is the ceiling on the data rate defined by the bus?
