[Solved] Drivers wont connect to windows 11 for the STM32L462RE. I have had success once using a docking station at my work but other thank that I am not sure what is going on here I cannot connect my device to the computer. Any advice would be helpful.
AVins.1
Device: STM32L462RE
2 REPLIES 2
Pavel A.
Evangelist III
For full USB compatibility, the hardware interface and your device firmware should be made correctly.
Windows 10/11 seems to be more picky about compliance with standards.
Try Linux on same or similar PC, if it won't behave better, then likely there's a hardware issue. Otherwise, look at the software (timing, format of descriptors...).
Sometimes a hub (such as in your docking station) can 'fix' electrical issues and make the device look good to the host.
AVins.1
Thank you! Doing a mix of that has made it successfully connect.
