2016-11-21 04:54 AM
Hey,
is it possible to use the I2C-SM-Bus-Modul as Slave or Master? I want use one I2C-Module as SM-Bus Slave and a other as Master.2016-11-21 10:47 PM
You'll find this information in the DS of the part you've selected.
While probably all I2C modules in STM32 are both (multi)master and slave capable (you still need to check on your own), some of them are not SMB-capable. JW
