Sinus generator
Andrei Gheorghiu
Posted on October 06, 2017 at 16:58
Hello, i have to make  a Sinus Generator can you please give me any hint or a gide how to start ?
Thank you.
5 REPLIES 5
Posted on October 06, 2017 at 17:41
Think I've previously demonstrated a TIM+DMA+DAC example feeding a sine wave table to the DAC at a defined pace.
Circular DMA on buffer
Triggered via a TIM at frequency X table length
DMA copies to DAC->DR
Andrei Gheorghiu
Posted on October 08, 2017 at 16:24
Hello again SIr,
Can you please send me a link with this example ?
Thank you verry much
Posted on October 08, 2017 at 19:00
https://community.st.com/0D50X00009XkiK9SAJ
Andrei Gheorghiu
Posted on October 18, 2017 at 20:02
Hello Clive,
I am i am stuck at a step in the code,
How can i make the DMA to allow 2 octet only for every IRQ from TIM5
To send to an external DAC.
Below is a link with my current project ,
https://drive.google.com/file/d/0B7fbIHd58fTedUtjVDBYajg4MUk/view?usp=sharing
Thank you for your support,
Best Regards,
Andrei
Posted on October 18, 2017 at 20:22
Really can't provide assistance with HAL code, you'd want to avoid placing blocking code in the IRQ Handler.
You might be better using a memory transfer to the SPI->DR in 16-bit mode using DMA triggered by a TIM on the same APB. ie not use a direct SPI+DMA linkage where SR.TXE drives the DMA service.
