SDMMC and USB Mass Storage Class (MSC).
‎2025-03-19 6:09 AM
I am using the STM32H745I-DISCO board, where Core M4 handles SDMMC and FATFS, and Core M7 manages USB Mass Storage Class (MSC). Is there a procedure or any available documentation on linking both cores for seamless data sharing?
- Labels:
STM32H7 Series
‎2025-03-19 4:40 PM
Sharing which data? Do you mean, sharing the filesystem on SD card between the CM4 and CM4 applications? (like, both CM4 and CM7 can create files on the SDcard?)
‎2025-03-19 10:22 PM
No. File system should create in m4 , Only file access needs to be implemented in USB.
1. Write all sensor data in flash through m4.
2. Collect stored data through M7 via USB mass storage
‎2025-03-20 2:28 PM
Very good, so the CM4 and CM7 just need to send data between them. Use any internal RAM that can be shared between them, and hardware semaphores for synchronization.
