2015-11-21 03:44 AM
2015-11-21 04:39 AM
Why wouldn't you paste in BOTH functions/lists?
Isn't the most probably reason that you cut-n-pasted the code, and didn't change all the things that need to be changed? Try turning off optimization I you think the compiler did some odd, common code, optimization.2015-11-23 01:45 AM
Please avoid removing the content of your posts. Thanks Clive1 for keeping the context of this one.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
