RXNE is never set.SPI always read 0
EMEYD.1
I am trying to use the SPI interface with a SPI ADXL345 sensor and the STM32F072 Nucleo board.I want to make a very basic read operation.Now the read function is blocked in waiting the the RXNE signal.But the RXNE is never set . SPI always read 0. I use IAR here is my codes, I use these functions too write and read SPI.
  int main()
  USART2_Init();
  SPIx_Init();
  while(1)
  adxl_baslat();
  receiveData[0] = readData(0x32) ;
  receiveData[1] = readData(0x33) ;
  receiveData[2] = readData(0x34) ;
  receiveData[3] = readData(0x35) ;
  receiveData[4] = readData(0x36) ;
  receiveData[5] = readData(0x37) ;
  x=( receiveData[1] << 8) | (receiveData[0]);
  y=( receiveData[3] << 8) | ( receiveData[2]);
  z=( receiveData[5] << 8) | ( receiveData[4]);
 xg=(float)x*0.0078;
yg=(float)x*0.0078;
zg=(float)x*0.0078;
  sprintf(buffer,"xg: %f yg: %f zg: %f \r\n", xg,yg,zg);
  USART_PutString( buffer);
   void SPIx_Init()
   SPI_InitTypeDef SPI_InitStruct;
  GPIO_InitTypeDef GPIO_InitStruct;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;
  SPI_InitStruct.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStruct.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStruct.SPI_Mode = SPI_Mode_Master;
  SPI_InitStruct.SPI_NSS = SPI_NSS_Soft | SPI_NSSInternalSoft_Set;
  SPI_Init(SPI1, &SPI_InitStruct);
  SPI_Cmd(SPI1, ENABLE);
  SPI_DataSizeConfig(SPI1, ENABLE);
  SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF);
  // Step 2: Initialize GPIO
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  // GPIO pins for MOSI, MISO, and SCK
  GPIO_InitStruct.GPIO_Pin = SPI_PIN_MOSI | SPI_PIN_MISO | SPI_PIN_SCK;
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_Init(GPIOA, &GPIO_InitStruct);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_1);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_1);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_1);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  GPIO_InitStruct.GPIO_Pin = SPI_PIN_SS;
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_Init(GPIOB, &GPIO_InitStruct);
  uint8_t sendByte(uint8_t byteToSend)
   timeout = TIMEOUT_TIME;
   while ((SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET)&
  (timeout!=0))
    timeout--;
  SPI_SendData8(SPI1, byteToSend);
  while ((SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE)==RESET)&(timeout!=0))
   timeout--;
  return (uint8_t)SPI_ReceiveData8(SPI1);
 void writeData(uint8_t address, uint8_t dataToWrite)
  DATA2 = address | 0x40;
  GPIO_ResetBits(GPIOB,GPIO_Pin_9);
   sendByte(DATA2);
  sendByte(dataToWrite);
   GPIO_SetBits(GPIOB,GPIO_Pin_9);
uint8_t readData(uint8_t address)
   address |= 0x40;
   address |= 0x80;
  sendByte(address);
  tempByte = sendByte(address);
   return tempByte;
void adxl_baslat(void)
writeData(0x31, 0x01);
writeData(0x2d, 0x00);
writeData(0x2d, 0x08);
2 REPLIES 2
Observe SCK pin using oscilloscope /LA- are clocks output there?
Read out and check the SPI and relevant GPIO registers content.
Initialize all fields in the init structs.
   timeout--;
For all the crap that's in HAL, at least they don't do junk like this where it checks for a timeout then just silently ignores when it happens.
Note that if you're observing the SPI->DR register in a debugger, you will reset the RXNE flag before it has a chance to take effect.
