Runtime DFU application via USB
dtarrago
Posted on April 10, 2017 at 12:16
Good morning,
Did you found the way to solve this? I'm trying to also implement RunTime DFU via USB port. Did you suceeeded? Which is the best example to follow?
Best regards.
STOne-32
Posted on July 23, 2017 at 20:09
Check our pre-defined examples in USB library  DFU in IAP mode. Else I missed your question ? Did you mean to have a composite example with a HID for example and DFU interfaces both active in run-time and once invoked for a device programming the DFUdriver will take the global control ?.
Cheers,
STOne -32
