2024-10-28 10:48 PM
STM32F038F6P6 -
Does the mentioned microcontroller have any certifications, particularly UL certification, which is not explicitly listed on its datasheet or its website?
If there are any, please mention.
2024-10-29 03:40 PM
Dear @SudhanshuModi ,
Here you go : X-CUBE-CLASSB - Class B 60730-1 and 60335-1 Functional Safety Package with software expansion for STM32Cube - STMicroelectronics then
STM32F0 library is here : https://www.st.com/resource/en/certification_document/ul_certificate.pdf
Certificate Number UL-US-L480533-111-81215102-2
Hope it helps you.
STOne-32.
2024-10-30 12:22 AM
OK, thanks for reverting but the certification that you shared is mostly for firmware with its library you shared, can you confirm UL certification for Hardware as well, for the same PN
