Quadrature encoder on STM32F429 discovery?
vasilevskialeksandar
Posted on October 15, 2014 at 09:26
I have working code on STM32F407 discovery board and would like to port it to discovery board based on STM32F429.
If I set GPIO_Mode_IN on STM32F429 I can see nice shaped signals from encoder on input pins PA1 and PA5. When I set GPIO_Mode_AF pins seems to be driven low from STM32F429 side.
AF is set to TIM2 with:
   GPIO_PinAFConfig(GPIOA,GPIO_Pin_5,GPIO_AF_TIM2);
   GPIO_PinAFConfig(GPIOA,GPIO_Pin_1,GPIO_AF_TIM2);
Code for timer setting is same for both STM32F407 and STM32F429:
    TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
    TIM_TimeBaseStructure.TIM_Period = 65536; //max resolution
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV4;//divide by clock by one
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;// count up
    TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
    TIM_EncoderInterfaceConfig(TIM2, TIM_EncoderMode_TI12,  TIM_ICPolarity_Falling, TIM_ICPolarity_Rising);
    TIM_ICStructInit(&TIM_ICInitStructure);
    TIM_ICInitStructure.TIM_ICFilter = 0;//ICx_FILTER;
    TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
    TIM_ICInit(TIM2, &TIM_ICInitStructure);
    TIM2->CNT = 0;
    TIM_Cmd(TIM2, ENABLE);//enable encoder
Any ideas what can be wrong or differences between 32F407 and 32F429 that can trigger this problem?
Regards,
Aleksandar
#quadrature-encoder-stm32f429
3 REPLIES 3
Amel NASRI
Posted on October 15, 2014 at 10:31
Hi Aleksander,
There are 2 axes for checks:
1- Hardware side: review differences between both boards that may impact your application.
2- Software side: if you are enabling alternate functions on pins PA1 & PA5 after enabling TIM2 clock please try to do the inverse & check again. I am interested to know results.
-Mayla-
Posted on October 15, 2014 at 12:29
   GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_TIM2);
   GPIO_PinAFConfig(GPIOA,GPIO_PinSource1,GPIO_AF_TIM2);
Posted on October 15, 2014 at 12:58
Thanks!
I made mistake during porting. After all both macros are really similar.
BR,
Aleksandar
