qspi data not compiling
MMARI.1
hi,
I am trying to external loader connect with stm32h723zgt6 + w25q128 .
before loading  the stldr file into debugger  i need know why cube ide not compiling the data into qspi location ?
In the main.c file constant data  has been declared as below .
const __attribute__((section(".extFlash"))) uint8_t buff[] = "Hello world from H723 QSPI";
In the flash id file has been modified as below.
QSPI_FLASH (r)    : ORIGIN = 0x90000000,  LENGTH = 16M
.extFlash :
     *(.extFlash)
  } >QSPI
 after compiling why memory details not showing in the below menu
SofLit
hello,
Try:
uint8_t buff[] __attribute__((section(".extFlash")));
PS:
hi,
i have modified as below :
uint8_t buff[] __attribute__((section(".extFlash")))= "hello world";
 but still problem continues as same !. it not showing as earlier attached picture
