Put function in RAM
DGo.1
how can I tell to the compiler that I want a function to be executed in RAM ?
9 REPLIES 9
Should be able to use an attribute or pragma to indicate which section a particular function is placed in by the linker. Code in the startup or scatter loader should move the code from ROM into RAM.
It is more of a linker directive than a compiler one.
DGo.1
Something like this ? :
#define EXEC_FUNC_ON_RAM __attribute__ ((section(".data")))
EXEC_FUNC_ON_RAM  void myFunc(int data) {....}
Do I have to modify the linker?
/* Initialized data sections into "RAM" Ram type memory */
  .data :
    . = ALIGN(4);
    _sdata = .;        /* create a global symbol at data start */
    *(.data)           /* .data sections */
    *(.data*)          /* .data* sections */
    *(.RamFunc)        /* .RamFunc sections */
    *(.RamFunc*)       /* .RamFunc* sections */
    . = ALIGN(4);
    _edata = .;        /* define a global symbol at data end */
  } >RAM AT> FLASH
Also, how do I check if the function in in RAM or FLASH ?
DGo.1
Found this; it worked correctly:
just add it before the function declaration:
__attribute__ ((section(".RamFunc")));
But don't add a semicolon in the end! Shall be:
__attribute__ ((section(".RamFunc"))) void some_function() {}
WojtekP1
Define section in RAM in linkerscript
use void procedureinram() __attribute__ ((section(".yoursectionname")) {procedure code}
of course it may not be void and may have any parameters.
Just tried that, same results
This is been tried, same results
Ignore this wrong post.
