program sram?
Staly.1
i wanna to program sram
the result follow:
No Algorithm found for: 02000000H - 02000A37H
Programming skipped!
Error: Flash Download failed - "Cortex-M0+"
about sram programming algorithm? only flash
5 REPLIES 5
Uwe Bonnes
Principal III
What dongle? What debugger?
Keil
You'd want to uncheck ​download to target, and instead use a debugger initialization file (.INI) which LOAD the .AXF or .HEX directly into RAM
It should probably map the RAM at zero.
Will see if I can create an example later.​
JLINK+SWD, keil mdk5
Staly.1
hi, clive1
​ thank you for your answer. i try to set a initialization file(.ini), it works.
then, i dont know how to disable flash
Staly.1
try to use arm-debug in vscode , ​how to debug a program in sram
