Problems with PWR_MODE STOP and the wake up with Timer LPTIM1
2018-10-30 4:26 AM
The LPTIM1 interrupt is running. But if I use the EnterStopMode function, the controller is not gone at the stop mode (LED1 come directly). If I use the EnterStopMode function the second time, the controller goes into the STOP mode and after few seconds the interupt wake up the controller (LED2 is delayed few seconds). Do I forget flags reset at first?
if (HAL_LPTIM_Counter_Start_IT(&hlptim1, 20000) != HAL_OK)
Error_Handler();
__HAL_PWR_CLEAR_FLAG(PWR_FLAG_WU);
/* ### - 4 - Enter in Stop mode ########################################### */
HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
LED1_ON;
//HAL_Delay(10);
LED2_ON;
//HAL_Delay(10);
LED3_ON;
- Labels:
LPTIM
2018-10-30 5:45 AM
Hi @AxelMC ,
Could you please precise which STM32 MCU you're using.
Khouloud.
2018-10-30 5:48 AM
Hi, I use the Nucleo Board L053R8 with STM32L053R8T.
2018-10-30 5:52 AM
Each time, if I set the LPTIM1, I have the problem
HAL_LPTIM_Counter_Stop_IT(&hlptim1);
HAL_LPTIM_Counter_Start_IT(&hlptim1, 50000);
one time ---> NO STOP
2 time --> STOP !!! ????
2018-10-30 6:03 AM
Hi @AxelMC ,
By default the LPTIM peripheral is deactivated in STOP mode. You have to activate it in order to work properly during this mode.
If you're using HAL, below is the instruction that you should call:
__HAL_RCC_LPTIM1_CLK_SLEEP_ENABLE() ;
Khouloud.
2018-10-30 6:12 AM
Hi Khouloud,
My probleme is the controller does not stop. If I enter the STOP Mode the second times, he stops and the Timer wake him up.
/* ### - 3 - Start counting in interrupt mode ############################# */
LED1_ON; // ---> Failure not STOPPED -- No Wait!!! :face_screaming_in_fear:
LED2_ON; // --> Come back after 10 sec
LED3_ON; // --> Come back after 10 sec
2018-10-30 6:47 AM
Hi @AxelMC ,
There is an example under STM32CubeL0, it's found under the path below:
STM32Cube_FW_L0_V1.10.0\Projects\STM32L053R8-Nucleo\Examples\PWR\PWR_STOP
Is it working using your HW? Please check it, maybe you're missing something.
Otherwise you may share your C files (main, msp,it) in order to verify if the issue is reproduced from my side.
Khouloud.
