OOmen
HMAC digest doesn't match expected (STM3221G-EVAL)
  • October 30, 2018
  • 5 replies
  • 1275 views
I just purchased the STM3221G-EVAL board and I am working through some examples. I am currently using running the HMAC example and it runs fine. However I am unable to get the HMAC to match the test vectors provided in the specification (https://tools.ietf.org/html/rfc2202).
Specifically for the following:
test_case = 1
key = 0x0b0b0b0b0b0b0b0b0b0b0b0b0b0b0b0b0b0b0b0b
key_len = 20
data = "Hi There"
data_len = 8
digest = 0xb617318655057264e28bc0b6fb378c8ef146be00
But I get a completely different digest.
Any ideas?
Many thanks in advance.
    After Forever
    Senior III
    October 30, 2018
    > Any ideas?
    I don't think so, at least not until you show us your code which doesn't work as expected :)
    OOmen
    OOmenAuthor
    Thanks [After Forever] - that was just a "hello world"
    Here is the code:
     * @file HASH/HASH_HMAC_SHA1MD5/Src/main.c
     * @author MCD Application Team
     * @brief This example provides a short description of HASH digest calculation
     * using SHA1 and MD5 example.
     * @attention
     * <h2><center>&copy; COPYRIGHT(c) 2017 STMicroelectronics</center></h2>
     * Redistribution and use in source and binary forms, with or without modification,
     * are permitted provided that the following conditions are met:
     * 1. Redistributions of source code must retain the above copyright notice,
     * this list of conditions and the following disclaimer.
     * 2. Redistributions in binary form must reproduce the above copyright notice,
     * this list of conditions and the following disclaimer in the documentation
     * and/or other materials provided with the distribution.
     * 3. Neither the name of STMicroelectronics nor the names of its contributors
     * may be used to endorse or promote products derived from this software
     * without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
     * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
     * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
     * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
     * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
     * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
     * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
     * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include "main.h"
    /** @addtogroup STM32F2xx_HAL_Examples
    /** @addtogroup HMAC_SHA1_MD5
    /* HASH handler declaration */
    HASH_HandleTypeDef HashHandle;
     "The hash processor is a fully compliant implementation of the secure
     hash algorithm (SHA-1), the MD5 (message-digest algorithm 5) hash
     algorithm and the HMAC (keyed-hash message authentication code)
     algorithm suitable for a variety of applications.*** STM32 ***"
    #define cINPUT_TAB_SIZE ((uint32_t) 8)/* The size of the input data "cInput" */
    #define cKEY_TAB_SIZE ((uint32_t) 20)
    // hex for "Hi There"
    __ALIGN_BEGIN const uint8_t cInput[cINPUT_TAB_SIZE] __ALIGN_END = {0x48, 0x69, 0x20, 0x54, 0x68, 0x65, 0x72, 0x65};
    __ALIGN_BEGIN const uint8_t cKey[cKEY_TAB_SIZE] __ALIGN_END = {,
     0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b,
     0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0xb0,
     0xb0, 0xb0, 0xb0, 0x0b};
    __ALIGN_BEGIN static uint8_t cSHA1Digest[20] __ALIGN_END;
    __ALIGN_BEGIN static uint8_t cExpectSHA1Digest[20] __ALIGN_END = {0xb6, 0x17, 0x31, 0x86, 0x55, 0x05, 0x72, 0x64,
     0xe2, 0x8b, 0xc0, 0xb6, 0xfb, 0x37, 0x8c, 0x8e,
     0xf1, 0x46, 0xbe, 0x00};
    static void SystemClock_Config(void);
    static void Error_Handler(void);
     * @brief Main program
     * @param None
     * @retval None
    int main(void)
     /* STM32F2xx HAL library initialization:
     - Configure the Flash prefetch, instruction and Data caches
     - Configure the Systick to generate an interrupt each 1 msec
     - Set NVIC Group Priority to 4
     - Global MSP (MCU Support Package) initialization
     HAL_Init();
     /* Configure the system clock to 120 MHz */
     SystemClock_Config();
     /* Configure LED1, LED3 and LED4 */
     BSP_LED_Init(LED1);
     BSP_LED_Init(LED3);
     BSP_LED_Init(LED4);
     /*************************** HMAC-SHA1 2 ************************************/
     BSP_LED_Off(LED1);
     HAL_HASH_DeInit(&HashHandle);
     HashHandle.Init.DataType = HASH_DATATYPE_8B;
     HashHandle.Init.pKey = (uint8_t*)cKey;
     HashHandle.Init.KeySize = cKEY_TAB_SIZE;
     if(HAL_HASH_Init(&HashHandle) != HAL_OK)
     Error_Handler();
     /* Compute HMAC-SHA1 */
     if(HAL_HMAC_SHA1_Start(&HashHandle, (uint8_t*)cInput, cINPUT_TAB_SIZE, cSHA1Digest, 0xFF) != HAL_OK)
     Error_Handler();
     /* Compare computed digest with expected one */
     if(memcmp(cSHA1Digest, cExpectSHA1Digest, sizeof(cExpectSHA1Digest)/sizeof(cExpectSHA1Digest[0])) != 0)
     Error_Handler();
     else
     BSP_LED_On(LED1);
     /*************************** HMAC-SHA1 2 repeat *****************************/
     BSP_LED_Off(LED1);
     Error_Handler();
     Error_Handler();
     Error_Handler();
     else
     BSP_LED_On(LED1);
     * The system Clock is configured as follow :
     * System Clock source = PLL (HSE)
     * SYSCLK(Hz) = 120000000
     * HCLK(Hz) = 120000000
     * AHB Prescaler = 1
     * APB1 Prescaler = 4
     * APB2 Prescaler = 2
     * HSE Frequency(Hz) = 25000000
     * PLL_M = 25
     * PLL_N = 240
     * PLL_P = 2
     * PLL_Q = 5
     * VDD(V) = 3.3
     * Flash Latency(WS) = 3
     * @param None
     * @retval None
     /* Enable HSE Oscillator and activate PLL with HSE as source */
     RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
     RCC_OscInitStruct.PLL.PLLM = 25;
     RCC_OscInitStruct.PLL.PLLN = 240;
     RCC_OscInitStruct.PLL.PLLQ = 5;
     if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
     Error_Handler();
     /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
     clocks dividers */
     RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
     RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
     RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
     if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_3) != HAL_OK)
     Error_Handler();
     * @brief This function is executed in case of error occurrence.
     * @param None
     * @retval None
     /* Turn LED3 on */
     BSP_LED_On(LED3);
     while(1)
    #ifdef USE_FULL_ASSERT
     * @retval None
     /* Infinite loop */
     while (1)
    #endif
    /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
    After Forever
    Senior III
    October 30, 2018
    0x0b0b0b0b0b0b0b0b0b0b0b0b0b0b0bb0b0b0b00b
    OOmen
    OOmenAuthor
    Aha - thanks.
    Fixed it but still no match.
    __ALIGN_BEGIN const uint8_t cKey[cKEY_TAB_SIZE] __ALIGN_END =   {0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b,
                                      0x0b, 0x0b, 0x0b, 0x0b};
    OOmen
    OOmenAuthor
    Here is what I get:
    0x75733ACAE127DD1DBFB2F8156E6A6E0C650B94B2
