Please, where can I find a "key_pair_generation" example code for the Discovery Kit B-L4S5_IOT01A? (STSAFE)
2021-04-26 6:26 AM
I tried porting the example code has been done for the Nucleo board to the B-L4S5_IOT01A but I get STSAFEA_COMMUNICATION_ERROR as result. SEE BELOW
Key pair generation demonstration:
1. Generate key pair through STSAFE-A's private key slot 1
=> Use StSafeA_GenerateKeyPair API
StatusCode = STSAFEA_INVALID_PARAMETER 48.
/* Check null pointers */
IS_STSAFEA_HANDLER_VALID_PTR(pStSafeA) 1.
IS_STSAFEA_CONDITIONAL_LVBUFFER_VALID_PTR(pOutPubX) 1.
IS_STSAFEA_CONDITIONAL_LVBUFFER_VALID_PTR(pOutPubY) 1.
pOutPointReprensentationId 48.
/* Check parameters */
**Inside StSafeA_TransmitCommand **
StatusCode StSafeA_TransmitCommand 0.
**Inside StSafeA_Transmit **
StatusCode StSafeA_Transmit 0.
/* Transmit */
StatusCode = STSAFEA_INVALID_PARAMETER 0.
/* after StSafeA_ReceiveResponse */
StatusCode StSafeA_ReceiveResponse 1.
StatusCode StSafeA_GenerateKeyPair 1.
2. Signature verification result (0 means success): 1
**key_pair_generation(&stsafea_handle) != 0 **
2021-04-26 7:55 AM
Hello @CMura.2 and welcome to the STM32 Community =)
You can download the software package for STSAFE-A from ST website: X-CUBE-SAFEA1.
When your question is answered, please close this topic by choosing "Select as Best". This will help other users find that answer faster.
Imen
Imen
2021-04-26 7:55 AM
Imen
Imen
