Peripherals missing in debug?
hexanpro
Posted on October 28, 2009 at 02:02
10 REPLIES 10
hexanpro
Posted on May 17, 2011 at 13:26
Hi!
I'm using the stm32f103zet6 and the rlink standard programmer, but when i'm in debuging mode, can't see some peripherals like uart4 and uart5... When i create the project and select stm32f103zet6 it shows that the device only have 3 Usarts, but in the datasheet refers to more two UARTs 4 and 5?
It is possible to debug them?
Thanks for your time...
tomas23
Push the IDE manufacturer to update their device database. It's clearly their fault not to implement the newest family additions.
Ask through their support channel.
st3
Quote:
Push the IDE manufacturer...
Absolutely - it's a specific issue with a particular IDE - so ask the IDE provider!!
It might be the user's fault - not using/configuring the product correctly...?
tomas23
If the device shows in the database? Your guess would be manual update of the database files with forgotten/screwed update of all IDE parts?
hexanpro
Thanks for your posts!
Some peripherals like TIM8 i already tested and is working as expected, but is missing from the peripheral tree when in debug mode. I take on other main.c and stm32f10x_it.c files from Ride7 library and paste only my code and run. Results: Only have 3 USARTS before, after i have the 5.
The SysTick, TIM5 to TIM8,and DAC is still missing...
And they are selected in stm32f10x_conf.h
hexanpro
Thanks for your reply.
How can i do that? Do you know what files i have to edit?
tomas23
Hi, it was comment to st7 about wrong update/user error.
You have to push the IDE manufacturer, anyway.
hexanpro
Thanks again..
So, you suggest that i send an email to raisonance reporting the situation?
st3
Isn't that the obvious approach?
Who is going to know Raisonance's products better than Raisonance themselves?!
