peripheral clock speeds on STM32f207
‎2014-05-21 12:43 PM
i am using STM32f207
i have a flash memory connected to SPI2. I used the ST examples and i got it working, read/write, .. great, ... the problem is the speed ... how fast can i run SPI2? There is a setting SPI_InitStruct.SPI_BaudRatePrescaler and the lowest value is SPI_BaudRatePrescaler_2In my SetSysClock function i set the dividers to 1: http://prntscr.com/3lbcy6This should give me the fastest speed?My flash goes up to 85MHz and i need to go at least 80MHz because there is a lot of data to read in short time .. will this be possible on SPI2? I have a 25MHz xtal on the board and i am running the ST at 120MHz via PLL.- Mark as New
‎2014-05-21 12:49 PM
maybe if i want to go that fast i need use I/O?
‎2014-05-21 12:55 PM
In my SetSysClock function i set the dividers to 1: This should give me the fastest speed?
Wouldn't it just break the buses? APB1 has a max of 30 MHz, APB2 60 MHz For faster flash interfacing consider SDIOUp vote any posts that you find helpful, it shows what's working..
‎2014-05-21 1:24 PM
i see .. i saw that in the ref manual but i did not want to believe it .. ok i will use i/o then .. thank you
‎2014-05-21 1:27 PM
can i connect SPI2 to AHB2?
‎2014-05-21 1:32 PM
about breaking the busses, HCLK is the xtal freq right? so 25mhz will not break ahb1 if i set the ahb1 divider to 1?
‎2014-05-21 2:11 PM
I'm not sure how you plan on achieving that without reworking the silicon.about breaking the busses, HCLK is the xtal freq right? so 25mhz will not break ahb1 if i set the ahb1 divider to 1? No, it's the CPU (PLL) clock at 120 MHz, or a fraction thereof (1 .. 512). Review the clock tree You could bit bang the part, as you suggest, there are other 4-bit (quad) SPI Flash devices too
‎2014-05-21 2:17 PM
‎2014-05-22 12:04 AM
From the DataSheet ...
''The STM32F20x devices feature up to three SPIs in slave and master modes in full-duplex and simplex communication modes. SPI1 can communicate at up to 30 Mbits/s, while SPI2 and SPI3 can communicate at up to 15 Mbit/s.'' Thus, even using all three channels simultaneously, the SPI hardware does not support the required throughput.- Mark as New
‎2014-05-27 5:15 PM
Thank you i setup the clocks correctly now .. switched to SPI1 and all is good now thank you
