NUCLEO-F722ZE Clock and MO2 issues
MHank.1
I'm attempting to set the clock to PLL on the board mentioned and view the output on MCO2.
This is some of the defines I use
#define REG_SET_BIT(reg,pos)   					((reg) |=  (1U << (pos)))
#define REG_CLR_BIT(reg,pos)    				((reg) &= ~(1U << (pos)))
#define REG_READ_BIT(reg,pos)    				((reg) &   (1U << (pos)))
#define REG_CLR_VAL(reg,clrmask,pos)   			((reg) &= ~((clrmask) << (pos)))
#define REG_SET_VAL(reg,val,setmask,pos) 		do {\
														REG_CLR_VAL(reg,setmask,pos);\
														((reg) |= ((val) << (pos))); \
												}while(0)
#define REG_READ_VAL(reg,rdmask,pos)            ((REG_READ(reg) >> (pos)) & (rdmask))
This is the code to configure MCO2
    RCC->AHB1ENR |= 4;
//    RCC->CFGR |= RCC_CFGR_MCO2_1 | RCC_CFGR_MCO2_0;
    RCC->CFGR |= (3U << 27);
    GPIOC->MODER &= ~(3U << 18);
    GPIOC->MODER |= (2 << 18);
    GPIOC->OSPEEDR |= (3U << 18);
    GPIOC->AFR[1] &= ~(0x0f << 4);
and the code I use to configure clock
	RCC_TypeDef* pRCC = RCC;
	FLASH_TypeDef* pFlash = FLASH;
	PWR_TypeDef* pPWR = PWR;
	// VOS setting
	REG_SET_BIT(pRCC->APB1ENR,RCC_APB1ENR_PWREN_Pos); 	/*Enable clock for PWR register access*/
	REG_SET_VAL(pPWR->CR1, 0x03U, 0x03U, PWR_CR1_VOS_Pos); 				/*VOS = 1*/
	// SET to use HSE clock
	REG_SET_BIT(pRCC->CR, RCC_CR_HSEON_Pos);
	while(!REG_READ_BIT(pRCC->CR, RCC_CR_HSERDY_Pos));
	REG_SET_BIT(pRCC->CR, RCC_CR_HSEBYP_Pos);
	// Main clock
	REG_SET_VAL(pRCC->PLLCFGR, 0x4U, 0x3FU, RCC_PLLCFGR_PLLM_Pos);
	REG_SET_VAL(pRCC->PLLCFGR, 160U, 0x1ffU, RCC_PLLCFGR_PLLN_Pos);
	REG_SET_VAL(pRCC->PLLCFGR, 0x00U, 0x3U,  RCC_PLLCFGR_PLLP_Pos);
	REG_SET_VAL(pRCC->PLLCFGR, 8U, 0x0fU, RCC_PLLCFGR_PLLQ_Pos);
	// PLL On
	REG_SET_BIT(pRCC->CR, RCC_CR_PLLON_Pos);
	while(!REG_READ_BIT(pRCC->CR, RCC_CR_PLLRDY_Pos));
	// Enable overdrive
	REG_SET_BIT(pPWR->CR1, PWR_CR1_ODEN_Pos);
	while(!REG_READ_BIT(pPWR->CSR1, PWR_CSR1_ODRDY_Pos));
	REG_SET_BIT(pPWR->CR1, PWR_CR1_ODSWEN_Pos);
	// Flash prefetch buffer
	REG_SET_VAL(pFlash->ACR, 6U, 0x7fU, FLASH_ACR_LATENCY_Pos);
	REG_SET_VAL(pRCC->CFGR, 0x2U, 0x3U, RCC_CFGR_SW_Pos);
	while(!(REG_READ_VAL(pRCC->CFGR, 0x3U, RCC_CFGR_SW_Pos) == 0x2U));
	// AHB, APB1 and AP{B2 bus dividers
	REG_SET_VAL(pRCC->CFGR, 0U, 0xfU, RCC_CFGR_HPRE_Pos);
	REG_SET_VAL(pRCC->CFGR, 5U, 0x07U, RCC_CFGR_PPRE1_Pos);
	REG_SET_VAL(pRCC->CFGR, 4U, 0x07U, RCC_CFGR_PPRE2_Pos);
When I configure MCO2 to output either SYSCLK or PLL I get nothing.
I'm thinking I should at least get a reading from SYSCLK.
I'm assuming that PLL is not being configured correctly and is using HSE as the system clock.
I'm wondering what I'm doing wrong configuring PLL as the system clock.
Any help appreciated.
PartsBin - An Electronic Parts Organizer for Windows @ JaxCoder.com
MHank.1
I found the solution after many hours of foundering and for those that wish to know the solution, here it is;
The solution is configuring the PLL as the clock source;
	// VOS setting
	REG_SET_VAL(pPWR->CR1, 0x02U, 0x03U, PWR_CR1_VOS_Pos); 				/*VOS = 1*/
	// Main clock
	REG_SET_VAL(pRCC->PLLCFGR, 150U, 0x1ffU, RCC_PLLCFGR_PLLN_Pos);
	REG_SET_BIT(pRCC->PLLCFGR, RCC_PLLCFGR_PLLSRC_Pos);
	// PLL On
	// Enable overdrive
	REG_SET_VAL(pFlash->ACR, 5U, 0x7fU, FLASH_ACR_LATENCY_Pos);
	FLASH->ACR |= FLASH_ACR_PRFTEN;
STTwo-32
Hello @MHank.1
I suggest you to use the following example wish configure SYSCLK to the maximum frequency using PLL and output the SYSCLK on the MCO1.
Best Regards.
STTwo-32
Thanks for the link but I'm no t using HAL.  I tried creating a HAL project and tried configuring per HAL but when I downloaded the HAL it didn't work either.
MHank.1
	// VOS setting
	// Main clock
	// PLL On
	// Enable overdrive
