Nucleo F303RE USB Serial Comm HAL example code?
‎2019-04-17 10:26 AM
I suspect there's example code for reading and writing serial data through the USB comm port (ST-link cable) on the Nucleo boards using the HAL libraries. Can anyone point me to one?
I've seen the printf() example which is half way there.
Thanks in advance,
Dave
- Labels:
STM32F3 Series
‎2019-04-19 2:34 AM
Hello @David Pekin​ ,
In the Step3 of "STM32 step by step", there is a description of what you need to do to perform serial writing.
It is based on STM32CubeMX, you need just to select the correct board at the beginning.
-Amel
‎2019-04-19 9:08 AM
Thanks. I'll take a look at it. I'll take a look at it. I've already got serial writing to the port via printf() & mapping PUTCHAR to the port. I'm now wanting to make a command prompt handler so I need the reading portion. I'm sure I can reinvent the wheel but thought it must be already around in some example.
Thanks again.
