Need to accurately read Manufacturer/Device ID using QuadSPI from a W25Q32JV (Winbond Flash).
Ahmed_KKK
I understand need to send Instruction 0x90, followed by 3 dummy bytes 0x00 to external flash. The rest configuration is OK. The code is as following.
This is SPI_INIT function.
static void MX_QUADSPI_Init(void)
 /* QUADSPI parameter configuration*/
 hqspi.Instance = QUADSPI;
 hqspi.Init.ClockPrescaler = 0;
 hqspi.Init.FifoThreshold = 4;
 hqspi.Init.SampleShifting = QSPI_SAMPLE_SHIFTING_HALFCYCLE;
 hqspi.Init.FlashSize = 23;
 hqspi.Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_2_CYCLE;
 hqspi.Init.ClockMode = QSPI_CLOCK_MODE_0;
 hqspi.Init.FlashID = QSPI_FLASH_ID_2;
 hqspi.Init.DualFlash = QSPI_DUALFLASH_DISABLE;
 if (HAL_QSPI_Init(&hqspi) != HAL_OK)
  Error_Handler();
and the following function is used to read ID from Flash. The Manufacturing ID is of 1 byte and Device ID is of 2 bytes. So the length is 3. Address is 0x00. how to send 3 dummy bytes (0x00). Shall I edit dummy cycles for it?
void QSPI_Flash_ID_Read(uint8_t *data, int length, uint32_t address){
 QSPI_AutoPollingMemReady(&hqspi);
 QSPI_CommandTypeDef sCommand;
 sCommand.InstructionMode  = QSPI_INSTRUCTION_1_LINE;
 sCommand.AddressSize    = QSPI_ADDRESS_24_BITS;
 sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
 sCommand.DdrMode      = QSPI_DDR_MODE_DISABLE;
 sCommand.DdrHoldHalfCycle = QSPI_DDR_HHC_ANALOG_DELAY;
 sCommand.SIOOMode     = QSPI_SIOO_INST_EVERY_CMD;
 /* Reading Sequence ------------------------------------------------ */
 sCommand.Instruction = READ_ID_CMD3; //0x90
 sCommand.AddressMode = QSPI_ADDRESS_1_LINE;
 sCommand.Address   = address;
 sCommand.NbData   = length;
 sCommand.DataMode  = QSPI_DATA_4_LINES;
 sCommand.DummyCycles = 0;
HAL_QSPI_Command(&hqspi, &sCommand, HAL_QPSI_TIMEOUT_DEFAULT_VALUE);
HAL_QSPI_Receive(&hqspi, data, 1000);
Ahmed_KKK
PROBLEM SOLVED!
Current settings for SPI QUAD I/O.
 /* Reading Sequence*/
sCommand.Instruction = 0x94;
sCommand.AddressMode = QSPI_ADDRESS_4_LINES;
sCommand.Address   = address;//0x000000
sCommand.DummyCycles = 4;
3 REPLIES 3
Pavel A.
Evangelist III
From the data sheet, the command 0x90 uses one output line. So,
 sCommand.DataMode  = QSPI_DATA_1_LINE;
Ahmed_KKK
PROBLEM SOLVED!
KDJEM.1
Thanks @Ahmed_KKK​  for sharing the exact solution. That may be helpful for other users.
