2009-10-15 11:21 PM
need help with sourcery G++ Lite for linux
2011-05-17 04:26 AM
hello.my project involves using stm32-p103 board.i have downloaded and installed the toolchain from codesouecery from
http://www.codesourcery.com/sgpp/lite/arm/portal/release830 i have followed the steps in the getting started manual and got stuck at the test program stage.it gives the same ''file or directory not found ''error inspite of adding the directories to path.this is very strange.manually i can navigate and see the files there.what to do? [ This message was edited by: abhinavbose87 on 15-10-2009 10:51 ]2011-05-17 04:26 AM
Quote:
On 15-10-2009 at 10:50, Anonymous wrote: hello.my project involves using stm32-p103 board.i have downloaded and installed the toolchain from codesouecery from http://www.codesourcery.com/sgpp/lite/arm/portal/release830 i have followed the steps in the getting started manual and got stuck at the test program stage.it gives the same ''file or directory not found ''error inspite of adding the directories to path.this is very strange.manually i can navigate and see the files there.what to do? [ This message was edited by: abhinavbose87 on 15-10-2009 10:51 ] Hello, Please send a short log of the error message 🙂 thanks.
