Need External Loader file for STM32H743IIT and MT25TL01G.
‎2022-02-01 7:07 AM
Hai,
we are using STM32H743IIT6 and External Twin quad spi (MT25TL01G).
In our board we have configured (PB6) pin for QUADSPI_BK1_NCS
but in the external loader file(MT25TL01G_STM32H743I-EVAL.stldr) which we have has PG6 pin for QUADSPI_BK1_NCS
Due to this pin conflict we are not able to program.
Could we get the external loader file which supports our pin configuration?
PB2-QUADSPI_CLK
PB6-QUADSPI_BK1_NCS
PF8-QUADSPI_BK1_IO0
PF9-QUADSPI_BK1_IO1
PF7-QUADSPI_BK1_IO2
PF6-QUADSPI_BK1_IO3
PC11-QUADSPI_BK2_NCS
PH2-QUADSPI_BK2_IO0
PH3-QUADSPI_BK2_IO1
PG9-QUADSPI_BK2_IO2
PG14-QUADSPI_BK2_IO3
QSPI
STM32H7 series
‎2022-02-02 11:40 AM
You must create own file stldr for load data to the external QSPI memory.
Please see this article:
https://community.st.com/s/article/source-code-of-external-loader
If You need help please contact directly.
I create file stldr for downolad data to QSPI memory MT25QL128 and MX25L512.
Best Regards,
Slawek
‎2022-02-01 9:06 AM
Have you proven your own hardware with your own BSP?
Do the MT25TL01G pair like that?
How many IC do you have on the board?
Customization work could be funded via PayPal
Best Regards,
Slawek
‎2022-02-02 6:43 PM
https://github.com/cturvey/stm32extldr/blob/main/h7_mt25tl01g/README.md
‎2022-02-08 3:54 AM
Thanks for the response. We will update you after we tried it.
M. Govind
