My STM32L051K8T6 gets stuck in an infinite loop in HAL_Delay(1000); but I know its a hardware problem, not a software problem. Where should I focus my hardware debugging on?
‎2021-10-15 11:30 PM
I have used this same chip on a previous project and managed to toggle an LED on and off using HAL_Delay(1000); function. I copied the same code across to my new project board, uploaded it successfully, toggled the LED on successfully but when I step into HAL_Delay(1000); it gets stuck infinitely.
I know it's a hardware problem because the same code works on my other board.
The thing that confuses me is the
- The STM32 allows me to upload my firmware and step through it, so I know the MCU isn't broken.
- I know the code works, as it works on my original board (different design, same chip).
What I'm asking for is there any places I should be looking for that might cause this problem on a hardware level, system clock problems?
Admittedly the MCUs are different batches, however I'm sure its just a layout problem.
This is the layout of the original board that works:
This is the layout of the board that isn't working:
Flash
STM32L0 Series
‎2021-10-16 12:47 AM
Hi *****.4,
From your hardware layout, check pin 31 - it looks like that is the BOOT0 pin and should be pulled to GND. On the board that is not working, you have left it floating.
Hope this helps
Hi *****.4,
Hope this helps
‎2021-10-16 8:53 AM
Boot0 can issue start code at all, but when code stuck isnt BOOT0 source.
HAL_Delay is based on nterrupts and in basic code you cant use it in ISR roiutines code without change priority .
I recommend first check your software.
‎2021-10-16 2:19 PM
Changing the hardware won't make HAL_Delay fail to work and let other code work fine. Perhaps revisit your assumptions as to if the code getting there in the first place.
‎2021-10-16 5:23 PM
Ensure the the FLASH is mapped into the Zero Address Space
In GNU, have code in startup.s
Reset_Handler:
ldr r0, =_estack
mov sp, r0 /* set stack pointer */
/*Check if boot space corresponds to system memory*/
LDR R0,=0x00000004
LDR R1, [R0]
LSRS R1, R1, #24
LDR R2,=0x1F
CMP R1, R2
BNE ApplicationStart
/*SYSCFG clock enable*/
LDR R0,=0x40021034
LDR R1,=0x00000001
STR R1, [R0]
/*Set CFGR1 register with flash memory remap at address 0*/
LDR R0,=0x40010000
LDR R1,=0x00000000
STR R1, [R0]
ApplicationStart:
‎2021-10-16 9:05 PM
Hi all, I wanted to just confirm that the problem was indeed hardware as I expected. As soon as I pulled the BOOT pin to ground (like pin 31 in the first photo was, but not the second), as per JVart.1's response there was no more issues with HAL_Delay, and everything runs as expected. (No code was just, just grounded the pin). Thanks all for your help!
