Memory check
jdmallett
Posted on August 23, 2008 at 07:40
Memory check
2 REPLIES 2
jdmallett
Posted on May 17, 2011 at 12:42
Does anyone have any experience or code to perform a flash memory check (CRC etc)? I am using the Ride7 compiler. I do have the STM32 Self Test library but they are geared towards the Keil or IAR compiler.
Thanks in advance!
James
lanchon
if you need to integrate checksums of your images into the build process you could check out ''srecord'' (it's GPL).
