SPI and DMA transfer
kay
Posted on August 22, 2008 at 10:12
kay
Posted on May 17, 2011 at 12:42
Hi, i have a Problem with a not correct working SPI Transfer.
I use DMA Transfer to load the data register and fetch the rx-data. Furthermore i use hardware nss because i hoped, that the DMA_Channel3->CNDTR
register is reset to initial value when NSS is disabled. But this doesnt seem to be the case? So a lost clock or a clock to much has impact on all further transmissions?! does someone have a solution?
