2012-10-25 7:25 AM
Hi.
Erased state of
f
lash memory in STM32L low-power devices is 0 instead ofmore common 1. What is the reason for this? If
I will
program unused flash portion to all FFh
, will
this impact current consumption in any way?
Thanks a lot
Jozef
#flash #low-power #stm32l2012-10-25 8:57 AM
Perhaps it's not flash, or they use an inverter.
I don't think the pattern you program is going to make any material difference on the current consumption of the static array. But if it was important you could experiment and measure it.
