2012-05-12 10:30 PM
Recently found a problem when test the F4 USB: I use the F4 Discovery chip version of 'A', the manual says this version , there are some bugs in USB. the Lib 2.1.0 ST OTG consider these bugs?
2012-05-16 6:53 AM
what kind of problem do you see ?
The 2 problems in Errata are for host mode and 2 for FS mode. Are you using USB-FS ? These are corner cases anyways.
