2017-02-02 2:51 AM
in the
the latest update field is empty. With the lastest update date given, a search for what has changed would be easy. Without that date, one has to navigate to the product and compare the document revision there with the the local revision.
Is there another way to see what documents changed?
2017-05-29 3:11 AM
Sorting by date now works as expected. Thanks!
Any thoughts about adding the datasheets to the resources?
2017-04-11 10:33 AM
the column 'Latest Update' now shows the dates. Thanks! But dates are sorted in alphabetical order, not calendaric order. So
'Apr 4, 2016' comes before 'Feb. 10, 2017'. Please rethink sorting order!
Cheers!
2017-05-05 4:22 AM
Sorting is still broken.
2017-05-05 7:09 AM
Bonnes.Uwe
,We have been working on it. It's now ready and testedon our pre-production server and will be ported to the production environment by the end of next week.
2017-05-06 6:47 AM
Thanks for working on that subject!
Are the data and errata sheets listed somehow in the same way? If not, I would suggest to list the under hardware resources as well.
2017-05-06 6:57 AM
'to list the under' -> 'to list them under'
2017-05-29 3:11 AM
