KSZ8863 RMII Interface and STM32f207 Communication
Options
2017-11-09 11:22 AM
Posted on November 09, 2017 at 20:22
I am currently using HAL library to interface my STM32F207 to a KSZ8863 switch using RMII Interface. The clock 25 Mhz provided externally which is then scaled to 50 Mhz to enable the interface. Now, I can read from the KSZ PHY register, i.e: I can read the CHIP ID and the default reset values but writing to the Ethernet PHY register is a complete failure.
Do I have to implement a bit bash mechanism as mentioned over here? Do I have to initialize both the PHY Ports?
Because I have tried that method and it is unsuccessful. I have pored through the datasheet to no avail. Does anyone have a solution or tips on how to proceed?Thanks and Regards.#ksz8863
1 REPLY 1
Options
2018-08-09 8:34 PM
Sorry, bumping old zombie unanswered questions off my feed
