2008-02-02 04:10 PM
Keil start-up files using GNU ?
2011-05-17 03:20 AM
Hi all,
I would like to use gnu compiler from codesourcery with Keil Toolchain and Ulink-Me, but I can not find any STM32 start-up nor linker files in the default installation. Thanks for your help. :-[ Magigimix [ This message was edited by: asterix.magigimix on 09-01-2008 00:38 ]2011-05-17 03:20 AM
Hi Asterix,
Were you able to find or make linker and startup files for codesourcery? Thanks!2011-05-17 03:20 AM
gcc startup files from Anglia IDEaliST
Cheers Spen2011-05-17 03:20 AM
plus default vector files
2011-05-17 03:20 AM
Hi, Did you manage to find a startup file and the linker script file, I would also like to use the GNU compiler with Keil. :( or could somebody at least point me in the right direction, as to where to get or how I could make my own?
Quote:
On 09-01-2008 at 00:06, Anonymous wrote: Hi all, I would like to use gnu compiler from codesourcery with Keil Toolchain and Ulink-Me, but I can not find any STM32 start-up nor linker files in the default installation. Thanks for your help. :-[ Magigimix [ This message was edited by: asterix.magigimix on 09-01-2008 00:38 ] :( :( :( :( :( :( :( :(2011-05-17 03:20 AM
thanks dudes, much appreciated!!! :D :D
2011-05-17 03:20 AM
see an alternative here
