Keil start-up files using GNU ?
asterix
Posted on February 03, 2008 at 01:10
7 REPLIES 7
asterix
Posted on May 17, 2011 at 12:20
Hi all,
I would like to use gnu compiler from codesourcery with Keil Toolchain and Ulink-Me, but I can not find any STM32 start-up nor linker files in the default installation. Thanks for your help. :-[
Magigimix
[ This message was edited by: asterix.magigimix on 09-01-2008 00:38 ]
lanchon
Hi Asterix,
Were you able to find or make linker and startup files for codesourcery?
Thanks!
sjo
gcc startup files from Anglia IDEaliST
Cheers
Spen
sjo
plus default vector files
rudi
Hi, Did you manage to find a startup file and the linker script file, I would also like to use the GNU compiler with Keil. :( or could somebody at least point me in the right direction, as to where to get or how I could make my own?
Quote:
On 09-01-2008 at 00:06, Anonymous wrote:
Hi all,
Magigimix
rudi
thanks dudes, much appreciated!!! :D :D
lanchon
see an alternative here
http://www.st.com/mcu/forums-cat-6304-23.html
