Java exception when running cube 4.8.0 on Linux
‎2015-06-15 8:10 AM
Exception in thread ''AWT-EventQueue-0'' java.lang.NullPointerException
at com.st.microxplorer.plugins.ip.gpio.gui.ParameterUI.addPropertyChangeListener(ParameterUI.java:156)
at javax.swing.plaf.synth.SynthPanelUI.installListeners(SynthPanelUI.java:83)
at javax.swing.plaf.synth.SynthPanelUI.installUI(SynthPanelUI.java:63)
at javax.swing.JComponent.setUI(JComponent.java:665)
at javax.swing.JPanel.setUI(JPanel.java:153)
at javax.swing.JPanel.updateUI(JPanel.java:126)
at javax.swing.JPanel.<
init
>(JPanel.java:86)
init
>(JPanel.java:109)
init
>(JPanel.java:117)
at com.st.microxplorer.plugins.ip.gpio.gui.ParameterUI.<
init
>(ParameterUI.java:72)
init
>(ParameterUI.java:101)
at com.st.microxplorer.plugins.ip.gpio.gui.ComboParameterUI.<
init
>(ParameterUI.java:431)
at com.st.microxplorer.plugins.ip.gpio.gui.ParamContainer.createPanel(ParamContainer.java:97)
at com.st.microxplorer.plugins.ip.gpio.gui.ParamContainer.update(ParamContainer.java:145)
at com.st.microxplorer.plugins.ip.gpio.gui.GpioTablePanel$RowListener.valueChanged(GpioTablePanel.java:192)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:184)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:154)
at javax.swing.DefaultListSelectionModel.setValueIsAdjusting(DefaultListSelectionModel.java:685)
at javax.swing.plaf.basic.BasicTableUI$Handler.setValueIsAdjusting(BasicTableUI.java:953)
at javax.swing.plaf.basic.BasicTableUI$Handler.mouseReleased(BasicTableUI.java:1166)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
at java.awt.Component.processMouseEvent(Component.java:6516)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
at java.awt.Component.processEvent(Component.java:6281)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4872)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4698)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747)
at java.awt.EventQueue.access$300(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:706)
at java.awt.EventQueue$3.run(EventQueue.java:704)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:720)
at java.awt.EventQueue$4.run(EventQueue.java:718)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:717)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219)
at java.awt.Dialog.show(Dialog.java:1082)
at java.awt.Component.show(Component.java:1655)
at java.awt.Component.setVisible(Component.java:1607)
at java.awt.Window.setVisible(Window.java:1014)
at java.awt.Dialog.setVisible(Dialog.java:1005)
at com.st.microxplorer.plugins.ipmanager.gui.BlockDiagram.createIpDialog(BlockDiagram.java:348)
at com.st.microxplorer.plugins.ipmanager.gui.BlockDiagram.actionPerformed(BlockDiagram.java:271)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
java version ''1.7.0_80''
Java(TM) SE Runtime Environment (build 1.7.0_80-b15)
Java HotSpot(TM) Server VM (build 80-b11, mixed mode)
‎2015-06-30 3:52 AM
‎2015-07-01 12:36 AM
‎2015-10-18 7:45 PM
Looks like a problem similar to http://stackoverflow.com/a/7555656/39431
From what I can tell STM32Cube is initializing a PropertChangeSupport object in the constructor and assuming it will be initialized before a call to addPropertyChangeListener is called but on non-Windows platforms it looks like addPropertyChangeListener can be called before the constructor is complete. A simple ensurePropertChangeSupport method could fix this right up.- Mark as New
‎2015-10-18 11:32 PM
‎2015-10-19 9:03 PM
I got bored tonight so I decided to create a little patch.
https://github.com/joeferner/stm32cubemx-patchBasically it goes in with Java byte code manipulation and fixes their code. I'm hoping I can throw this code away soon it kinda makes me sad to look at.- Mark as New
‎2015-10-23 11:17 PM
Running 4.1 and seeing the same problem as you and everyone else but to fix it I'm lost! Unfortunately, 40 years of assembler and 'C' experience doesn't help with the vocabulary of java.
Unpack - this is a basic unzip into a working directory - yes?
Runjava com.fernsroth.stm32cubmxpatch.Patch <gpio dir>
I get the following error
robin@robin-desktop:~/src/stm32cubemx-patch/src/main/java$ java com.fernsroth.stm32cubmxpatch.Patch ~/tmp/gpio
Error: Could not find or load main class com.fernsroth.stm32cubmxpatch.Patch
Repackage
gpio.jar
- no idea what utility I'd use to do this.
A few crumbs on how to proceed would be great
‎2015-11-16 1:56 AM
Dear user,
Please note this issue will be fixed with CubeMX 4.12. Best regards- Mark as New
‎2016-02-09 3:12 AM
This issue is now fixed in STM32CubeMX 4.13 Best regards
