2018-08-20 06:41 AM
2018-08-20 07:48 AM
System memory is not user-reprogrammable.
Write your own bootloader located into the first sectors of the user memory.
2018-08-20 08:42 AM
ST's code is provided in OTP, you don't get to reprogram it. I suppose if you did $10M in business you might be accommodated.
Done SD card based loaders, can be done in 16KB of FLASH
