Is it necessary to connect VDDA in STM32F030R8
‎2017-09-13 9:22 PM
Greetings People,
Is it necessary to connect VDDA in STM32F030R8 ? I am not using ADC in my application. Any suggestions would be of great help.
#analog-supply #external-powerSolved! Go to Solution.
‎2017-09-13 10:50 PM
The power on reset uses it, as does the PLL, check power supplies section of Reference Manual (RM0360). If designing a board you really should review the Data Sheet and Reference Manual.
‎2017-09-13 10:01 PM
Yes,
connect Vdda to Vdd.
and Vssa to Vss.
‎2019-01-04 6:57 AM
In this case a Filter RLC in VDDA is necessary?
‎2019-01-04 6:57 AM
