internal flash
‎2018-02-19 12:57 AM
hello! i am working with stm32 cortex-M0? IN FACT i want to know how to modify bytes from the internal flash without erasing the whole page , in addition i don't have RAM space to copy code there and modify bytes there !! is there anyone who can help ?
Note: this post was migrated and contained many threaded conversations, some content may be missing.- Mark as New
‎2018-02-19 1:20 AM
When cross-posting (ie, posting the same question to multiple forums), always include links between the threads.
Otherwise you waste people's time as they give an answer in one thread - not knowing that it has already been given in another.
See:
http://www.keil.com/forum/63375
on the Keil forum.A complex system designed from scratch never works and cannot be patched up to make it work.
‎2018-02-19 2:43 AM
you told me to ask on ST forum !!
‎2018-02-19 2:56 AM
Looking at the Keil forum link, it seems rather like re-direction than cross-posting ...
First, you.
The specific part is nowhere mentioned, you could be a tad more specific.
IN FACT i want to know how to modify bytes from the internal flash without erasing the whole page ...
That's usually the way it is, microcontroller must be cheap.
The datasheet/ref.manual tells you what your part has implemented.
If you can't live with it, select a (more expensive) dual-bank variant, or add external NVRAM (Flash, EEPROM, MRAM, ...).
‎2018-02-19 3:05 AM
Yes, it is.
But the point remains:
- An answer had already been given in the original thread - that should have been acknowledged here.
- The original thread should be updated to link to this 're-direction'.
‎2018-02-19 3:07 AM
Or look for a (possibly more expensive) microcontroller with internal NV memory (EEPROM, FRAM, ... )
‎2018-02-19 3:18 AM
The datasheet/ref.manual tells that i can only erase page , i tried to copy data to stack buffer then modify them there but it doesn't work so that's why am asking is there an other solution !!
‎2018-02-19 3:34 AM
Or that, yes.
But with the few information we got up to now, all this amounts to crystal-ball-gazing.
Yet again ...
‎2018-02-19 3:49 AM
Perhaps you should explain what exactly are you trying to achieve. What are you using the flash to store? How big is the data structure? How often does it change?
‎2018-02-19 4:03 AM
So where's the doubt, then? That seems pretty clear!
So you must have been doing it wrong, then.
And you have been given a list of possible options
