2011-02-18 10:26 AM
Interface 1.8V STM32 to 3.3V SD Card?
2011-05-17 5:25 AM
I might add....
Current frontrunner solution is the TI TXB0108.2011-05-17 5:25 AM
We're using the TXS0206 for the same purpose.
2011-05-17 5:25 AM
What you're looking for is a called a ''voltage level translator''.
You just have to be sure it meets your requirements ( In or Out ( or both ), speed, voltage levels, etc ... )2011-05-17 5:25 AM
Thanks for the pointer to the TXS family. With its internal pullups it looks like the TXS0108 will be a better fit than the TXB0108.
